实力封“印”镍矿
批量870H交付
LiuGong 870H Loaders Empowers Efficient Production of Nickel Mines in Indonesia
3月,柳工向印尼苏拉威西一镍矿项目交付一批870H装载机。这批装载机延续了柳工设备品质高、适应性强和安全可靠等优势,为当地镍矿生产注入强劲动能,获得客户的高度认可。
In March, LiuGong delivered a batch of 870H loaders to a nickel mining project in Sulawesi, Indonesia. These loaders, inheriting LiuGong's advantages of high quality, strong adaptability, and safety, injected strong momentum into local nickel mine production and gained high recognition from customers.
强劲动力 效率拉满
Powerful & Efficient
此次交付的设备主要应用于电厂煤炭工况,在相同作业条件下,相较之前提升两倍的工作效率,通过现场工作数据对比,真实呈现了柳工870H装载机在工况中的省油和高效表现。
The equipment delivered this time is mainly used in coal-fired power plant conditions. Under the same operating conditions, the work efficiency has been doubled compared to before. Through on-site work data comparison, it truly demonstrates the fuel-saving and efficient performance of LiuGong 870H loaders in various conditions.
创新引领 高效节能
Innovation-driven, Energy-Saving
整车采用“肌肉感”十足的全新外观设计,并搭载柳工自主研发的全自动控制系统和定变量液压系统,作业时能够根据负载需要自动调节流量,有效避免溢流功率损失,在大幅降低操作强度的同时,进一步提高节能效率。
The loader adopts a new exterior design with a strong “Muscular” style. It is equipped with LiuGong's independently developed fully automatic control system and variable displacement hydraulic system. During operation, it can automatically adjust the flow according to the load requirements, effectively avoiding overflow power loss. While significantly reducing operational intensity, it further improves energy efficiency.
此外,该机型采用加强型干式桥和前车架,保障在重型工况作业中更强的承载能力和更高的可靠性。
In addition, this model uses reinforced dry axle and front frames, ensuring greater load-bearing capacity and higher reliability in heavy-duty operating conditions.
勇担重任 稳定可靠
Stable & Reliable
基于载荷谱优化发动机特性,870H应用“驼峰曲线”技术,有效提升动力性能,并配备行业领先的柴油机变速箱减震装置,将驾驶室的振动降低40%,即使在满载作业的情况下,也能保证整车运行的平稳和流畅。
Based on load spectrum optimized characteristics, the 870H applies the “tuned engine curve” technology, effectively improving its power performance. It is equipped with industry-leading diesel engine gearbox shock absorbers, reducing cabin vibration by 40%, ensuring smooth operation even under full load conditions.
有奖征集
欢迎与我们分享更多您与柳工的故事。
分享内容一经采用,
即有定制好礼赠送!
相关图片、视频及文章(未经发表)
可发送至:
overseas.marketing@liugong.com
2002年提出“建设开放的国际化柳工”至今,柳工已拥有超过30家海外子公司&机构,4座海外制造工厂,5大全球研发基地,300多家经销商,为170多个国家和地区提供产品和服务。在打造具备全球竞争力的世界一流企业背景下,柳工将持续积极建设全价值链协同发展的全球战略合作伙伴关系,坚定推进全面解决方案、全面智能化、全面国际化的“三全”战略。
In 2002, LiuGong put forward the globalization strategy. Since then, LiuGong has had over 30 overseas subsidiaries & offices, 4 overseas manufacturing plants and 5 R&D bases spreading across the world. More than 300 dealers provide LiuGong products and services to the customers in over 170 countries & regions. Guided by the reform of building a world-class enterprise with global competitiveness, LiuGong will continue to actively build a synergistic global strategic partnership across the entire value chain by firmly promoting the "Total Globalization, Total Solution and Total Intelligent" strategy.
关注我们
