铁甲工程机械网> 工程机械资讯> 行业 > 新品来袭!柳工M200E铣刨机
新品来袭!柳工M200E铣刨机
工M200E 2米铣刨机主要适用于高速公路、国道、省道、市政道路、机场跑道等大面积维修和白改黑路面以及桥梁的快速拉毛等工况。设备可靠,操作简单,轻松提高施工日产量。优化的整机重量和先进的技术确保施工灵活性和施工效率。
LiuGong M200E two-meter milling machine is mainly suitable for large-area maintenance and white-to-black pavement of highways, national highways, provincial highways, municipal roads, airport runways and other working conditions such as fast brushing of bridges. With reliable and simple operation concept, it achieves high construction daily output. Optimized machine weight and advanced technology ensure high flexibility and efficiency.
>>>> 滑动查看
主要参数
Specifications
操作质量
Operating Mass
35000 kg
铣刨宽度
Milling Width
2000 mm
铣刨深度
Milling Depth
0-330 mm
额定功率(G3)
Rated Power/Rated Speed (G3)
563/2100
Kw@rpm
强劲动力,节能环保
Strong Power, Energy Saving
G3/563kw、G4/478kw发动机,多种澎湃动力可选
G3/563kw, G4/478kw Cummins engines are available, various surging power
发动机双动力曲线控制,负荷自适应控制力强,降低油耗
Engine dual power curve control, load adaptive control force, reduce fuel consumption
铣刨深度达330mm
Milling depth up to 330mm
高效铣刨,自适应强
Efficient Milling, Adaptive to Working Conditions
146、162、276多种刀具选择,适应各种工况铣刨,水泥、沥青均可铣刨
A variety of cutter options: 146, 162, 276
Adaptive to various milling like cement and asphalt
可定制672把刀头,超间距6mm铣刨
672 cutterheads with super pitch 6mm milling is available
三档铣刨速度设计,无级调节
Three milling speed, stepless adjustment
输料无极速度调节,输送能力最高达375 m³/h,快速平稳,效率高
Infinitely adjustable speed of material conveying with a maximum conveying capacity of 375 m³/h, fast and efficient
四履带同步驱动,动态显示转向,前履带、后履带多种转向方式,适应各种工况
Four track synchronized drive, dynamic display steering, multiple steering modes for front track, and rear track, adaptive to various working conditions
数字显示,智能控制
Digital Display, Intelligent Control
实时动态显示各种数据及整机工作状态,操作简单,控制精准
Real-time dynamic display of all kinds of data and the working status of the whole machine, simple operation and precise control
无须对刀,一键铣刨,自动关联,一键回中,一人完成,降低操作难度,提升工作效率
No need to match the cutter, one key milling, automatic correlation, one key back to the center, one person to complete, reduce the difficulty of operation, enhance work efficiency
双低噪音风扇,智能温控
Double low noise fans, intelligent temperature control
可选视觉系统,减少视觉盲区
Optional vision system, reduce the visual blind area
集成自动找平系统,铣刨厚度可控
Integrated automatic leveling system, milling thickness can be controlled
保养便利、维修快捷
Convenient Maintenance
大开度发动机上罩及侧门,宽敞的维护保养空间
Wide-open engine hood and side doors, spacious maintenance space
滤芯及维修检测点成组集中布置在触手可及的位置,保养方便快捷
Filter elements and maintenance inspection points are centrally located within easy reach, making maintenance more convenient
安装的高压冲洗装置,方便整车清洗
Installation of high-pressure flushing device, convenient for cleaning the whole vehicle
具有故障自诊断功能
Self-diagnostic function
有奖征集
欢迎与我们分享更多您与柳工的故事。
分享内容一经采用,
即有定制好礼赠送!
相关图片、视频及文章(未经发表)
可发送至:
overseas.marketing@liugong.com
2002年提出“建设开放的国际化柳工”至今,柳工已拥有超过30家海外子公司&机构,4座海外制造工厂,5大全球研发基地,300多家经销商,为170多个国家和地区提供产品和服务。在打造具备全球竞争力的世界一流企业背景下,柳工将持续积极建设全价值链协同发展的全球战略合作伙伴关系,坚定推进全面解决方案、全面智能化、全面国际化的“三全”战略。
In 2002, LiuGong put forward the globalization strategy. Since then, LiuGong has had over 30 overseas subsidiaries & offices, 4 overseas manufacturing plants and 5 R&D bases spreading across the world. More than 300 dealers provide LiuGong products and services to the customers in over 170 countries & regions. Guided by the reform of building a world-class enterprise with global competitiveness, LiuGong will continue to actively build a synergistic global strategic partnership across the entire value chain by firmly promoting the "Total Globalization, Total Solution and Total Intelligent" strategy.
关注我们
