在施工行业,压路机的高效运行对于工程质量至关重要。正确的保养不仅能延长机械使用寿命,还能确保施工安全和效率。以下是针对恒旺压路机的保养和维护的精简指南。
In the construction industry, the efficient operation of road rollers is crucial for the quality of engineering projects. Proper maintenance can not only extend the machinery's lifespan but also ensure construction safety and efficiency. Below is a concise guide to the maintenance and care of Hengwang road rollers.
01
PART.
Storage and Transportation Maintenance
保管及运输保养
在非工作期间,正确的保管和运输是保障压路机性能的关键。选择干燥的存储环境以防锈蚀,并确保足够的防火措施。运输时,使用适当的锁紧装置和运输方式,以防机械在运输过程中移动或脱落。
During non-operational periods, proper storage and transportation are key to preserving the performance of road rollers. Choose a dry storage environment to prevent rust and ensure adequate fire prevention measures. When transporting, use appropriate locking devices and methods to prevent the machinery from moving or falling off.
02
PART.
Operate According to the Manual
按照使用说明书操作
遵循说明书的指导进行操作和保养,分为走合期保养和等级保养两个阶段。在设备的磨合期,应定期检查和调整,更换润滑油,保证紧固。等级保养分为三级,从基本的检查和维护到全面的检查、调整,以及设备的彻底检修和清洁。
Follow the instructions in the manual for operation and maintenance, which are divided into two stages: running-in maintenance and graded maintenance. During the equipment's running-in period, regularly check and adjust, change the lubricating oil, and ensure everything is tightly secured. Graded maintenance is divided into three levels, ranging from basic inspection and maintenance to comprehensive checking, adjustment, and thorough overhaul and cleaning of the equipment.
03
PART.
Maintenance Measures
维护措施
压路机的维护主要集中在清洁、润滑和防腐锈上。定期清洁机油、空气和柴油滤清器,以及电气部分,是维持设备正常运行的基础。适当的润滑保证发动机和传动部分的高效工作。采取有效的防腐措施,如涂抹油脂或油漆,以保护设备。
The maintenance of road rollers mainly focuses on cleaning, lubrication, and rust prevention. Regularly cleaning the oil, air, and diesel filters, as well as the electrical parts, is fundamental to keeping the equipment running smoothly. Proper lubrication ensures the efficient operation of the engine and transmission parts. Effective rust prevention measures, such as applying grease or paint, protect the equipment.
04
PART.
Special Environment Maintenance
特殊环境保养
在暴晒或大雨等特殊环境下工作时,应采取额外的保养措施。关注设备运行状况,避免发动机过热。定期检查燃油系统,确保燃油管道畅通无阻,检查排气系统和燃油箱的密封性,避免漏气和其它潜在问题。
When working in special environments like direct sunlight or heavy rain, take extra maintenance steps. Monitor the condition of the equipment to prevent engine overheating. Regularly check the fuel system to ensure fuel lines are clear and inspect the exhaust system and fuel tank for seal integrity, avoiding leaks and other potential issues.
通过这些精心规划的保养和维护措施,可以确保压路机的高效、安全运行,为施工项目提供坚实的支持。正确的保养不仅延长了设备的使用寿命,也为施工团队创造了更加安全和高效的工作环境。
Through these meticulously planned maintenance and care measures, the high efficiency and safety operation of road rollers can be ensured, providing solid support for construction projects. Proper maintenance not only extends the life of the equipment but also creates a safer and more efficient work environment for the construction team.
-END-
山东恒旺集团以“让最广泛的用户享受最高性价比的产品及服务”为使命,不断推出新产品,提供全方位服务。主营产品类目齐全,包括挖掘机、推土机、钻机、打桩机、压路机、履带运输车等20大系列180余种。产品通过ISO、欧盟CE、德国TUV、法国BV等十余项安全检测认证。
Shandong Hengwang Group, with the mission of "providing the widest range of users with the highest cost-effective products and services," continuously introduces new products and offers comprehensive services. Our main product categories are comprehensive, including excavators, bulldozers, drilling rigs, piling machines, road rollers, tracked transport vehicles, and more, totaling over 20 series and 180 varieties. Our products have obtained more than ten safety testing certifications, including ISO, EU CE, Germany TUV, France BV, and others.
干工程、选恒旺、事业兴旺!
免费热线:400-9975-666
欢迎致电
